Take the 2-minute tour ×
I recently laid a new concrete shower pan, and went around the drain radially, which created some circular ridges.
I'd like to make the pan as smooth as possible, but these ridges are currently 1/8" to 1/4" high. How can I level these out, and do I even need to worry about it if I'm laying thinset when I put my tile down?
add comment
1 Answer
up vote 4 down vote accepted
You probably don't need to concern yourself. The thinset plus tile should smooth out the imperfections just fine.
If you really want to remove them, you'll probably need to use a concrete grinder. But that's pretty expensive. As a "lightweight" alternative, a 4" angle grinder with a masonry wheel would knock the top off of the ridges. But it would take a lot of time and make a lot of mess to really remove much material that way.
add comment
