We are planning to install bead board paneling to our kitchen back splash, and new Formica for the counter tops. Which product should be installed first, and why?
up vote 4 down vote accepted
There are advantages to doing it either way.
If you put the paneling up first, and slid the counter top back so it overlaps the panel a bit, you'll get a very nice looking edge if properly caulked.
BUT, doing it this way runs the risk of water running down the back splash, and running behind the counter, creating a rot/mould risk on the cabinetry underneath (particularly if the caulk fails).
If the paneling goes over the counter top, you mitigate the water risk, but it's going to be a lot harder to get a good looking edge.
This was my concern. Caulking the bead board (if placed on top of counter) might look messy, but beats having moisture running down the back. The solution might be to put a narrow piece of trim over the caulk. Thank you for your insights. – RET Sep 19 '12 at 20:22
I was thinking about the trim as well. It might get in the way. – Chris Cudmore Sep 19 '12 at 20:24
I would have concerns about long term exposure of the wood to sink splash. – mikes Sep 19 '12 at 20:27
A piece of shoe molding placed over the properly caulked seam between the counter and bead board should create the nice looking finish you want without taking up any serious space. Plus, caulking it as well adds an additional layer of protection for water leakage. – The Evil Greebo Sep 19 '12 at 20:29
Thank you all for your comments...I hadn't considered the sink splash issue, and may need to rethink this. – RET Sep 21 '12 at 4:54
