Tell me more ×
I have bought bamboo fittings in the bathroom (towel holders, dishes etc). I see that as a result of hanging damp towels on the towel holders, a black mold is accumulating on the bottom of the holder bar.
What would be the best treatment for the bamboo in order to seal from the elements?
edit: I live near the sea and things do not dry as quick as i would want them to. And no, there are no extractor fans in the bathroom.
How often do you clean the bathroom? Do you wipe the towel bar down from time to time? Do you have an exhaust fan in the bathroom, and do you run it during and after showers? – Tester101 Sep 17 '12 at 19:08
@Tester101, thanks i have edited the post. I think your advice is great about the exhaust fan, i will probably go that route, however i also feel that these bamboo products are too porous at the moment, they need to be "sealed" – Hightower Sep 18 '12 at 6:17
Since you bought the fittings I have to ask - what did the manufacturer instructions say about finishing? – The Evil Greebo Sep 18 '12 at 10:48
they say nothing about finish... just some marketing mumbo-jumbo... see the website dejay.co.za/category/bamboo-range – Hightower Sep 18 '12 at 10:52
Wow that website is about as uninformative as it possibly could be... – The Evil Greebo Sep 18 '12 at 10:57
1 Answer
up vote 2 down vote accepted
A standard approach to sealing is polyurethane, either brush on, rub on or spray on. If the old finish is pretty solid, a light sanding may do. If it is not adhering well or where the piece is worn and stained, a more thorough sanding is needed. In all cases, you need to wipe off all dust, preferably with a tack cloth before finishing. Wiping down with mineral spirits also helps clean before finishing.
A dust mask is always a good idea when sanding, especially if there is a chance that mold is present.
A much harder finish is marine or spar finish. While originally varnish, it is now available in a urethane formula as well.
spar urethane
These types are specificly formulated to hold up better in wet environments.
For almost all types of finish, two or more coats are needed for a durable protection.
