I have a small holiday apartment in Europe that has pre-fabricated concrete walls. The surfaces are relatively smooth but I want to prepare them for painting by applying a skim coat of plaster. Which kind of plaster is the most appropriate for this purpose.
By the way, these are internal walls.
up vote 1 down vote accepted
Any top coat plaster should be OK.
It might be worth priming the surface with a diluted PVA solution (5 parts water to 1 part PVA - from memory so double check) to seal it.
Is it possible to just seal the wall, prime it, and then paint (maybe using a thick nap roller) avoiding have to put down any plaster? After you have sealed and primed the wall, a coat (or two) of paint with a thick nap roller might be able to smooth out any small defects in the pre-fabricated wall. And painting is going to be much easier than putting plaster down. (Of course patch any major defects in the wall prior to sealing it.)
I agree, priming (maybe putting down UGL drylok to help with any possible moisture issues) would be a much better idea than plastering. – Scott Vercuski Sep 14 '10 at 13:39
