Tell me more ×
We have a kwikset deadbolt on our main door and the faceplate has come loose. There are no visible screws on either side of the door, so I am assuming they are under the brass plate on the inside of the door. I can't seem to get the plate off though. There is a little rectangle on the bottom of the plate, but it doesn't seem to help pop off the plate. The locking handle seems too close for the plate to be allowed to moved enough to reach screws anyway. Does anyone know how to get the plate off?
1 Answer
The Kwikset locks I've replaced had screws on the deadbolt plate, but I've heard that others have a 'snap-on' plate that can be removed with a flathead screwdriver. This forum post seems to concern a case similar to yours.
Yup, gently work a flat head screw driver around the plate to loosen it (especially if there is paint holding it on) and then with your fingers try and turn it counter-clockwise. It should pop off at this point. – Jeff Widmer Sep 14 '10 at 2:04
