Tell me more ×
I would like to make a cheap DIY dance floor and I attained a roll of 3.5 ft x 6 ft vinyl linoleum for free. Can I use this in making a dance floor? Has anyone built their own cheap DIY and what materials did they use? Has anyone failed at doing this and what should I avoid? Are there any good guides to doing this on the internet?
What is the original surface that will support the dance floor? Is it supposed to be temporary (removable) or permanent? – Joe Philllips Sep 11 '10 at 16:20
It should be a removable floor. There are a few of my friends interested in the question in general (for a cheap diy floor without the free linoleum) and they will have different floors. Some suggestions for a carpet would be great. If you have suggestions for different floors please share those as well. – D W Sep 11 '10 at 17:42
What type of dancing? – Tester101 Sep 15 '10 at 16:52
@Tester101, I'm curious why that matters. I guess it it was riverdancing or stomp it would be tougher on the floor. Anyways, we will be doing salsa, lindy hop, and blues. – D W Sep 15 '10 at 22:27
@Tester101 I stand corrected about the type of dance mattering. This site has a table of the floor you need based on the type of dance: stagestep.com/floortools_styleuse.php – D W Sep 21 '10 at 18:01
up vote 4 down vote accepted
Here is an article (How to Make a Temporary Dance Floor) on how to make a dance floor from Medium-density fiberboard (MDF) and some old scrap carpeting. Home Depot also sells carpeting by the roll and it is pretty inexpensive (then you could get just the right size fit for the MDF boards and also the area of your dance floor).
Purchase MDF and scrap carpet at a hardware store specific to your measurements. Standard MDF will be 3/4 inch thick and will be cut into 4 feet by 8 feet pieces. You should have the MDF cut into pieces that will fit easily into your space. Purchase the same amount of scrap carpet to place underneath the MDF.
Glue the scrap carpet to the underside of the MDF. This will prevent your floor from being scratched and will provide cushioning for your feet and knees.
Great link, thanks. Would upvote you but I don't have the ability yet. – D W Sep 17 '10 at 16:49
Would a bamboo rug work?
alt text
It'd be easy to roll up when not in use. I don't know if it's a great dancing surface, though.
This may just work with the linoleum. I would upvote you but I don't have enough points yet. I will look more into this. – D W Sep 17 '10 at 16:47
