I need to replace the washer on this tap as it keeps leaking.
The tap design seems quite similar to the one described here, but it seems the middle section cannot be turned (it's completely round, doesn't have any nut ridges).
Can this model be taken appart?
The top cap seems to have some notches to be able to turn it, but I think it's actually fused to the handle. Maybe it needs lot of WD40?
Update:
With lots of fiddling around, the top came off by turning (didn't pry up), so those notches actually helped.
Now, I think the cover should come out by spinning, but there is no way to grab hold to spin it. The tiny notch seems to be more likely a defect, or maybe made by some previous guy attempting to fix it. It's not deep enough to insert a screwdriver to help spin it.
Any ideas on how to proceed next?
