I will be installing some new 12x12 tiles in two bathrooms approx 25 sq/ft each. When I pulled up the old tiles, there was no thin set that had made contact with them so the removal was very easy. Now, the thin set on the floor is a different story. I have been chipping away at it by hand in one bathroom to get to the cement floor below and it has been a bugger to get off. Before I attempt to continue this process in the second bathroom, I would like to know if it is absolutely required to do so if it is well adhered to the cement underneath?
(It's my hope, obviously, that I can tile over the old thin set as long as it is level and firmly attached.)
EDIT: My subfloor is a concrete slab with the thin set on it. It must be chipped away to remove vs. cut and replace sub floor.
Is there a mechanical device that I can use to speed up the process? So far I have had two days with a cold chisle, screwdriver and hammer in my removal attempt in bathroom one and still have some to left on the floor. – Carl B Sep 8 '12 at 12:55
You can use a power chisel, air hammer, or demo hammer. – BMitch Sep 8 '12 at 13:29
@BMitch - Thanks for the suggestion. Could you put that as an answer so I may consider accepting it along with other potentential solutions. – Carl B Sep 8 '12 at 13:34
By the way that scraper that fits in your sawzall is trash. . it broke my recipricating saw they aren't made for that type of impact – Dion May 12 '15 at 4:45
Always, always, always wear a dust mask when grinding, sanding or cutting thinset or concrete. The dust can eventually cause silicosis which can be deadly!!! – user41971 Aug 30 '15 at 4:19
10 Answers 10
up vote 17 down vote accepted
Like Greebo says, you want to get back down to the concrete, but I'd suggest that more to have a flat surface to build on top of. To make the job go faster, you can use a power tool. Several would get the job done:
Power Chisel (best fit for the job):
power chisel
Air Hammer (you'd need a high capacity air compressor):
air hammer
Demo Hammer (more power than you need, but it could be useful for other jobs in the future):
demo hammer
MC Hammer (don't touch this):
mc hammer
Since it's thinset on slab, I agree - get yourself a power chisel - rent from Home Depot for the day. – The Evil Greebo Sep 8 '12 at 15:55
I will rent the power chisle to get the thin set off. The MC hammer was an option I didn't even think about....Hmmm Can't touch this....Could be handy if I go far with the power chisle and he could warn me that I have gone to far into the concrete. lol. Nice touch! – Carl B Sep 8 '12 at 16:02
MC Hammer might not be useful, but Vanilla Ice might be able to help. – Tester101 Sep 10 '12 at 12:02
Extra upvote for MC Hammer. – Karl Katzke Sep 11 '12 at 18:46
How about MC Hammerhead? – sborsher Jan 14 '15 at 18:51
Having done this exact thing recently, I found that using the hard metal brush attachment for the angle grinder worked very well to remove thinset without affecting the concrete beneath it. I'd lean towards the stiffer bristles.
Be sure to wet the thinset before starting, and as needed. The thinset comes off like mud, leaving clean concrete. Once finished, scoop up the mud and sweep.
Done.
up vote for your comment - The walls have just been painted in the bathrooms. Will this fling the "mud" all over the place? Can it be done with misting water to keep the dust down? I like this idea as well. – Carl B Sep 9 '12 at 16:39
The mud flings laterally. I did it by taping a six inch cardboard "curb" around my work area. It couldn't hurt to put up some plastic but I found it unnecessary. I kept it wet with a brush in a bucket of water. You will know when It's too dry. If there is dust add water. Thinset will readily absorb. – Matthew Sep 9 '12 at 17:58
I have GOT to get me one of THESE! – The Evil Greebo Sep 10 '12 at 18:11
Also, you will know if you're brushing concrete because you'll likely see small sparks as the concrete reacts to the steel brush differently than the thinset. Brushing the concrete will wear the brushhead out, the thinset shouldn't affect it much. I used two of these brushheads to do about 100 sqft. – Matthew Sep 14 '12 at 15:02
Wow I wish we had read about that when we were chipping up thinset after breaking up tile! We used an air hammer with a high capacity air compressor, but it probably took close to 20 hours to do a small bathroom plus 6x6 hallway and 3x3 closet. I think the thin-set used was some heavy duty stuff too. IT WAS HORRIBLE. We have one more area to go so maybe the grinder option would be the way to go for the next part. Would that also work for linoleum glue? I think our glue is water soluble. – Angela L. May 11 '13 at 15:31
The answer is, "if you want to do it properly, yes". You're going to find it near impossible to get a good base to lay tile on if you try to apply thinset overtop of old thinset.
You may find it actually easier to remove the subfloor completely (cut it out with a circ saw set to the depth of the subfloor) and replace it to give yourself a clean surface on which to work.
+1 for your reply.The thin set is applied directly to the concrete slab. There is no way I can cut, remove replace the sub floor. – Carl B Sep 8 '12 at 12:59
Fair enough - go with BMitch then – The Evil Greebo Sep 8 '12 at 15:56
If I could choose both answers I would. Your input was most helpful and I wish I could give you some of my rep for taking the time to answer. TY. – Carl B Sep 8 '12 at 19:15
Not necessary. :) – The Evil Greebo Sep 9 '12 at 2:55
After calling the rental places and comparing what I have done (using a cold chisle and hammer) to the results I would anticipate with a power chisle, I opted for the cheaper (and now added tool to the tool chest) of a $39 Royobi 4.5" angle grinder. I attached a two row Dimond cutting cup about $40. At Matthew PK's suggestion to water the floor down, it did eat it up and make mud. In three hours I finished the bathroom I started by hand and finished the second bathroom! Floors are smooth as glass and I was able to tile both rooms the next day.
All suggestions/Answeres were most appreciated.
You easily can go over old thin set with no problem,as long as it is down good....I have done whole house on top of strong bonded oldthinset....it is actually a benefit to the instsllation of the new tile....only a pro can understand what I mean....but trust me ,it is okay
"Only a pro can understand what I mean." Really? That's a little condescending. Since the whole point of DIY.SE is learning about home improvement, why don't you give explaining what you mean a shot? – Doresoom Oct 2 '14 at 13:33
You can put tile over old thinset. Make sure it not loose, vacuum to remove any debris, check for cracks, apply membrane if needed. I've done it hundreds of times for fifteen years including my own five houses. Remove the old thinset to get a flat surface for wood or laminate installation.
Just finished removing tile and thin set from a small (5'x5') bathroom floor an hour ago. I use a wide cold chisel and hammer to remove the tile. I found it was much more productive to cut through the grout lines first with an angle grinder and diamond blade. You could use a circ. saw but I didn't have one on hand. I used my shop vac to collect the dust as I ran along the grout with the blade. You don't really need to go all the way through the grout to the subfloor, just a decent groove. The tile still broke up in pieces with the grout lines cut but the pieces were much larger making the job faster.
I found a wide chisel / scraper type attachment at Lowes which fit directly into a recip. saw and that made pretty short work of the thin set ridges. Going perpendicular to the ridges is much more effective. Altogether the job took about 4 hours and left the new surface pretty smooth. I may just hit any high spots with the grinder again to make sure. It's a little late to do it once you start laying tile.
well, chipped all the tile up in my home OMG. So now the thinset, I found a rental tool at homedepot .Its a floor buffer and you put this round buffer with teeth and it removes thinset.DUST but fast. and yes you can go over thinset just make sure it not loose. have fun ;)
thinset removal bit $25 on amazon hooks up to an air compressor. .. gives you more control than a roto hammer. Been doing tile for 10 years and so far best bang for your buck
wet the thinset with a generous amount of water before attempting to remove. It will soften most thinsets up a bit but the biggest gain is in dust mitigation. Let it soak as long as you can, I try to let it set for at least an hour. You will have a tremendous amount of dust EVERYWHERE if you don't. There will still be dust but it will be manageable when wet. I just scaled 150 square feet today and although it was a back breaker it wasn't nearly as bad as it could've been. Used a Bosch rotary hammer with a 1.5" scaling bit. Couldn't find a wider bit but this actually worked well. I use a 4" manual scrapper to ensure everything is flush and this really cleans any remaining thinset. Good luck, it isn't for the faint of heart !!!
