I've seen some people recommend that cement board be glued and screwed to the stud framing for wall and ceiling application.
I haven't seen this recommendation on any of the manufacturers install specs, but it seems to come up often enough in DIY and other web communities as a way to keep the board fixed and rigid with the framing.
