Tell me more ×
I want to use a water source reverse cycle heat pump AC for a 8000m2 aged care facility.
Location has moderate summer (22 deg C max) and cold winter (<0 deg c).
On site pond is only 400m3. I understand this is a bit small. Is there a way to get water source heat pump to work without having to increase size of pond?
Calling this "Home improvement" is stretching things. Anyway, the laws of thermodynamics are cruel. If the pond is too small, then as you draw too much heat from the water, it will undergo a phase change. That phase change will be encouraged when the outside air temperature is below freezing. – woodchips Sep 3 '12 at 11:59
Lawrence, consider asking this on the Gardening And Landscaping site. There are a number of questions about ponds there. – Alex Feinman Sep 4 '12 at 14:07
closed as off topic by woodchips, Steven, ChrisF Sep 4 '12 at 12:46
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
