(A Velux blind is a brand of skylight/roof-window in the UK that's apparently quite popular).
We have a couple of velux windows with blinds attached. We'd like to swap them for the black-out blind variety, but having ordered the new ones, are at a bit of a loss for how to uninstall the current ones.
How to best do this? Couldn't find any information on velux's site.
up vote 0 down vote accepted
Adding an update to Peter Mounce's answer from: https://zebbakes.com/2011/06/21/how-to-uninstall-a-velux-black-out-blind/
The Mr McDonald method at the end worked for me in a couple of seconds, and doesn't have the crazy screwdriver involvement. The quote is:
spoke with a very helpful chap at Velux (UK) and removed the blind quite easily. Method was this: 1) With the blind retracted fully, grasp the casing firmly at each end with your fingers at the back (between casing and glass) and thumbs on the front. 2) Now twist/rotate the case up and out (as if twisting case toward top of window frame) and listen for the ‘click’ of the catches releasing both sides. 3) When both catches released – blind should slide forward and out! Tried it and it worked a treat! Obviously no guarantee but was reassured by Velux that if the clips should break on attempting removal that they can supply a new set of brackets for re-installation.
I was looking for information and the best link I found was http://zebbakes.com/2011/06/21/how-to-uninstall-a-velux-black-out-blind/, which was both informative and amusing.
It says to take a flat-head screwdriver, wrap it in a cloth, and then insert it between blind and glass, then twist it in small increments until the blind pops out by brute force.
It is possible to break the glass by using this method.
I have been able to do it using my hands - they are not massive. Simply by swinging the velux round and using the same technique as above but with my hand and I little bit of brute force. It is off and no part broken. Whoopee!
Thank you Graeme. We have been trying on and off for a week or two with ours and your technique worked in about ten seconds. Open window, grab blind in middle and use to move window up and down until the blind comes out in your hands. Mine has left two plastic plaques on the window frame which I guess the blind was clicked onto. We didn't install it so not sure. – user38007 May 30 '15 at 12:38
I agree that using your hands is the best option. I have just finished replacing seven old blinders with shiny new ones and I could remove them all without damage (not that I cared!) by simply pulling with my bare hands. It takes a while to understand that you must not pull towards you but slightly down
We have three velox windows and each had a blackout blind with a "Night Sky" finish.
  1. Removed (and clean) side fittings.
  2. Removed the slide spring ends (and clean).
  3. Opened window and grasped blind cassette with both hands and gently opened / closed the window = Bingo ! In less than 20 seconds the cassette came away from the window fittings.
  4. Cleaned the cassette.
  5. Re-installing cassette into the left hand window.
Unscrew the side strips and slide down the windows to remove from the cassette If you look down the side of the cassette you will see the grey plastic mounting which the cassette clips onto.
There is a small piece of sprung plastic on the side of cassette which locks it in place.
If you carefully slide a thin blade between the cassette and the grey mounting (I used a butter knife because it is flat and about the right width) keeping the edge of the blade close the top of the window you can push the sprung plastic clip back and the cassette drops out easily - no force required.
