Possible Duplicate:
Does the NEC allow electrical wiring to run next to a ventilation duct?
My house has recently been converted to 200-amp electrical service, and I would love to run some new wire to take advantage of that fact. My house was converted from forced air to hot-water baseboard heating. My question is: can I run electrical wire through the old heating ducts to save myself quite a bit of hassle? What if there are hot water pipes in them? Is it advisable to/must I use conduit, or would Romex suffice?
marked as duplicate by Steven, ChrisF Aug 31 '12 at 11:49
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
^ while the question is not the same, KeithS provides the answer to your question (short answer: no) – Steven Aug 30 '12 at 17:47
I will let someone else weigh in on the NEC compliance, but likely it is allowed (I am guessing it is the same as retrofitting and fishing a wire through an empty wall cavity).
However, I would definitely not do this with NM wire, since there's a high chance there are sharp metal edges and other protrusions that can damage the wire creating a safety and fire hazard. BX (armoured) would be more appropriate, and easier than trying to get NM through conduit and into the vents.
You don't see a problem with either the completely empty ducts, or the ones with the hot water pipes? – Brendon Aug 30 '12 at 17:11
