Take the 2-minute tour ×
On painting the bedrooms in our new house, we've gotten some (mainly) water-based paint on some of the paving slabs on the patio. A little of it may be oil-based gloss we used for skirting boards, but the majority is emulsion.
Is there an easy way to remove it without a lot of laborious scrubbing? I was rather hoping the rain might make it fade, but it's been a few weeks and that was clearly overly optimistic on my part ;)
4 Answers 4
The water based paint will come off eventually with rain and normal activity on the paving slabs, but it will take a while.
The only guaranteed way is to use water and a scrubbing brush or, if you don't want to get down on your hands and knees, a stiff bristled yard brush.
A pressure washer might do the trick. Look upon this not as a chore of tedious magnitude, but as an opportunity to acquire more tools!
Pressure Washer
Generic image -- not an endorsement of any particular brand.
Buying no-name products can sometimes lead to inferior performance. –  Tester101 Sep 17 '12 at 17:43
Sure - any chemical paint stripper for latex paint. You might also try a heat gun and scraper, and then the chemical stripper.
Just think of it the same way you would exterior latex housepaint - use the same products intended to strip that.
If it hasn't stained the concrete a pressure washer should do the trick. I use my Karcher 1800 PSI all the time on my concrete driveway when I painted some doors on saw horses and didn't take the time to put down a tarp.......took it right off no problem and no stains however, I did it right away after painting the doors.......like the next day!
