Sign up ×
My sump pump battery monitor was beeping. I changed the battery because the message said that the battery was not working. Not 24 hours later the battery was beeping again! Do I need to do anything special since I just bought a new marine battery from an auto parts store? Any help would be greatly appreciated. The beeping is driving my crazy!!!
closed as not constructive by Steven, The Evil Greebo, Chris Cudmore, ChrisF Sep 18 '12 at 12:01
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, visit the help center for guidance.If this question can be reworded to fit the rules in the help center, please edit the question.
These things have a battery AND a battery charger. You wanted to verify why the battery went dead. If the charger is not working (or maybe is not even plugged in?) then the new battery will die too.
Check that power is getting to it. Check that the charger is working. Check all connections.
