Tell me more ×
I'm a new home owner and was wondering if there is a "right" way to use the double hung windows in the house. Should I open the top or bottom? Is there a seasonality to it? Does it even matter at all?
Double Hung Window
I've looked around and haven't seen this answered well or with most anything other than a "try and see."
Generally, is there anything special I should know to maintain the windows?
Can anyone shed some light?
Vote to reopen as "Best practices for a specific task." is on topic, and window maintenance/repair/operation is definitely DIY related. – The Evil Greebo Aug 27 '12 at 18:37
When I closed it, my thinking was that this is a general homeowner question, and not something that has to do with home improvement. I know there is an "is there something I should know to maintain the windows?" in there; if that were the main part of the question, I think it would be acceptable. – Vebjorn Ljosa Aug 27 '12 at 18:46
I went back in forth in my head with the same question but I ultimately settled on the way The Evil Greebo was thinking. Thanks for eyes on this. – Rob Aug 28 '12 at 12:17
I open the top, it helps keep the damn cat off the screens while she looks out the window. – Freiheit Aug 30 '12 at 13:22
up vote 5 down vote accepted
Generally one opens the bottom window, simply because it's easier. The features of the window tend to be designed with that in mind:
  • the screen (if it is original to the window) will usually have a bit of extra fill along the top edge where it meets up with the upper window's bottom edge
  • if there is a partial open lock (that prevents complete opening) it'll be designed to stop the bottom window from opening more than a few inches (though it really works both ways.
It's really up to you, however. There are good reasons to open the top instead - for instance, if you have small children and having them climb around the window is a concern. (No kidding - my friends 5 year old fell out a 3rd story window when the screen popped out)
Follow Up: Another consideration to opening the top -my preferred method to keep papers from flying around the room- is that in relation to that gap @The Evil Greebo mentioned above. We had stinkbugs this past summer and I eventually found them getting into the house through that small gap created by the missing edge on the screen. Small but nice to know up front. – Rob Dec 14 '12 at 15:30
If you open both the top and bottom about 3" the hot air goes out the top and cooler air comes in the bottom.
Tall windows on rooms with 12' ceilings = Antebellum Air-conditioning in the southern US until electricity and modern air-conditioning units became available. The high ceiling kept the heat well above you and the high and low window openings allowed for air flow. – Fiasco Labs Mar 18 at 22:53
If you have regular blinds/shades you may find it more useful to open the bottom, since that will allow unrestricted airflow. If you have Top Down/ Bottom Up blinds/shades, you might find it gives you a bit more privacy if you open the top of the windows and blinds.
Some windows will have locking mechanisms that allow you to lock either the top or bottom in place, while the other moves freely. In this case, it can offer better security if you can lock the bottom and open the top. A burglar would have to climb higher to gain access to the open window (though they could always just smash the windows, so it's not a huge security gain).
You may have animals (cats, etc.) that enjoy the open window, in which case they'd probably prefer you open the bottom.
For bedrooms with only a single window, in the summer I like to put a window fan in the bottom (blowing in) and then open the top of the window to vent. Alternately, if there's an AC in the window but you don't want it on, you can open the top of the window to get fresh air without removing the AC unit. (My windows have screens that can slide up to the top of the window which is nice, although not all are like that.)
If you have awnings or eaves that overhang the windows, opening the top may reduce the chance of rain blowing in.
