I have PU polish on veneer in my wardrobe. I accidently put a heavy weight over it, so polish seems to have left the veneer and appears as white. How can i fix it? Will using hot iron work? Kindly suggest
Tell me more
No, heat will usually mar it further. I've had some success in simply buffing the white discoloration with a soft cloth. I have a terry bathrobe that has be relegated to rag status that I use. |
