Tell me more ×
We removed the plaster from several walls because they were friable and bulging, but chose to leave the lath attached to save time/work. We will screw 1/2 inch drywall onto the walls, but upon further consideration are concerned that the lath underneath may cause irregularities in the finished product. Is this an acceptable practice or should we remove the lath also?
1 Answer
up vote 5 down vote accepted
Any imperfections in the wall will be easily visible through the drywall. It will form waves that conform to the surface behind it. When laying out walls in a new build, we make sure every stud has the bow or cup facing the same direction to minimize this. And any stud that is too badly twisted is re-purposed (usually for shorter cripples under windows).
I would recommend taking a long flat surface (either a straight board or a level) and making sure all the walls are flat, both vertically and horizontally. They can be out of level by a bit, but flat is important. If this reveals lots of bulges or cups in the wall, flatten it while it's exposed.
If you find it's not flat and pull the lath, you may still find the studs are not flat. For any studs that have a significant cup in, you can sister a second stud beside it to give a good nailing surface, just be sure it's not on a seam between two sheets of drywall. And if any studs have a significant bow out, you can plane them down slightly (though if you have to remove more than a half inch, I'd sister another stud for structure).
One other consideration, junction boxes for outlets and switches are standardized for installing on studs with drywall, so you'll have an easier time replacing them at the 1/2" depth if you're down to the studs.
Thank You for your immediate answer. Another question arises...if we install drywall over the lath will it be tight enough, ie, will it 'suck up' and be rigid enough and not pose later problems of screws backing out or drywall bowing? – RET Aug 25 '12 at 15:51
@RET You don't want any gap between the back of the drywall and the surface you're screwing into. Otherwise the screw will go straight through the drywall as it blows out the back (drywall is strong against compression, the paper surface only does so much to contain expansion). So if you can't hit the lath with the screw and have a tight connection between the drywall, lath, and stud, I'd recommend against it. – BMitch Aug 25 '12 at 16:31
Thank You...we think it best to remove lath to avoid issues...more work, but better result in the end. Thanks again! – RET Aug 25 '12 at 17:13
