Is there a way to remove Styrofoam bits from my equipment efficiently?
Tell me more
If you have an air compressor, you can get an attachment called an air blow gun.
Since Styrofoam is so light, you should be able to simply blow it away. This tool is also helpful, if you want to make your friends laugh.
If you don't have a compressor, you could use canned air to blow the Styrofoam away.
If you don't have that either, you could always use your lungs.
Thanks BMitch for pointing out the more obvious solution... Use a f***ing ShopVac!
You can set the vac to blow, if you still want to blow the Styrofoam around for a bit. |
