Tell me more ×
With so many window and door recessed contact switches, how does one decide the best one for the application?
I was leaning towards Ademco 3/8" Diameter Miniature Press Fit Magnetic Contact, for both windows and doors mainly because it provides (in a "stubby" profile):
1-1/4" the largest gap of any mini 3/8" contact
I'm assuming this would help in preventing false alarms due to minor gaps between the contacts.
However, here is just a short example of the additional recessed contacts options available:
Stubby with Rare Earth Magnet
Stubby with Rare Earth Button Magnet
Short/Stubby
Stubby
Standard or Long
Standard
When would I choose one over another?
Not enough information I think. Can you supply pictures of the areas you want to use them? – GdD Aug 23 '12 at 13:01
What exactly do you mean by areas? I basically have windows and doors that I want to install contact sensors into. I'm assuming the correct choice will be very specific to the door and window, however, I wasn't sure what other factors may determine the best choice. – Steve Aug 23 '12 at 13:06
What type of windows do you have? Recessed switches are a pain to install for a lot of windows (such as vinyl). Also, just as a heads up, drilling a hole in your window frame can void your warranty. – user1563835 Aug 23 '12 at 13:08
These are the windows: silverlinewindows.com/vinyl-windows/new-construction-windows/…. Why is it difficult to install? Doesn't it just require a hole drilled, wires spliced, and run to control panel? – Steve Aug 23 '12 at 13:12
It really all depends on the window material. You'll want to have the hole drilled in a way where the switch isn't exposed to the outside environments and weather. – user1563835 Aug 23 '12 at 13:26
show 2 more comments
1 Answer
up vote 3 down vote accepted
I'm looking at doing the same thing in my house later this year. But, I want to emphasis that drilling through your windows/window frame can void your warranty. If these are new windows, you'll want to have that warranty in place just as an "what if" happens in the near future. You'll have to refer to your warranty documentation to see if drilling will void your warranty.
The Ademco 3/8" Diameter Miniature Press Fit Magnetic Contact looks pretty standard. Just to be on the cautious side, you can always measure your frame to see if you have enough space. Otherwise, I see no issues with installing these on your door and the frame. Also, I've seen them installed on the top of the door or the side of the door. That's your call.
You may want to re-consider and utilize non-recessed/surface mounted contact switches for your windows and its frame. First of all, research more about your windows. If they contain spring mechanisms in the inside of the window or the window frame, then you will not be able to drill a hole. Otherwise, if there are no physical obstructions, then you can normally drill the required diameter near the bottom of the window. You want to make sure that the hole is covered and not exposed to the outside environment. If exposed, you could use some sealant to protect the contacts. Also, if your windows are double-hung, you'll need contacts installed at the top and the bottom of the window. You can connect the two contacts in a series so that you don't have to run two sets of wire to the control panel.
All the recessed options you provided are for different scenarios of windows/doors. Normally, regular sized contacts are used except where these sensors may be too large to fit the door or window frame. Stubby contacts would be used in such occassion. The stubby/earth magnet contacts are great for window applications because of the size of the magnet (depending on your window type, you may not need to drill into your window to fit the magnet).
I am going with the stubby/earth magnet contact for the windows. Too many unknowns with what I am drilling into, and warranty implications. If there are no downsides of this contact, then I don't see the benefit of the press fit ones that require drilling into the windows. I am using miniature press fit ones for the doors. Thanks for your help. – Steve Aug 24 '12 at 0:45
@Steve No problems, best of luck with your project! – user1563835 Aug 24 '12 at 1:19
