Before staining the pine wood siding of my balcony, I used MINWAX stainable wood filler to cover nail holes and knot cracks.
The holes are filled alright, but there is a yellow blotch where the excess product was. Sanding (120 grit) does not make it go away, the wood is stained.
Unfortunately, thinking this product was like plastic wood (which does very well on pine, after sanding, only the hole shows with the filler), the job is done and now I have patches of yellow blotches everywhere.
What should I do to get rid of this?
You can be sure I won't be using this product on pine again.
