Tell me more ×
I assumed the manufacturers of the fencing would sell an optional sleeve to protect the power-coating on the posts from the repeated scraping of the trimmer cord, but they do not? Does anyone have any ideas? Is this even needed? enter image description here
Stop hitting it with the weed whacker? ;) – The Evil Greebo Aug 21 '12 at 19:48
This trimmer has a guard to protect flowers and gnomes, but nothing to protect fence posts. – Tester101 Aug 21 '12 at 19:51
Already have a trimmer with no guard. – Evil Elf Aug 21 '12 at 19:54
Don't you have to hit it with the trimmer cord to trim the grass up on it? – Evil Elf Aug 21 '12 at 19:54
You could buy a replacement Universal Trimmer Guard – Tester101 Aug 21 '12 at 19:55
Get a piece of approprietly sized PVC pipe or corragated plastic drain pipe.For a 4 inch post use pipe with at least a 4 inch inside diameter Cut it into 6-9 inchs long pieces. Slice the pieces so you have 1/2 of a piece of pipe. Bury the pipe about 3-6 inches into the ground so it covers the base of the post. Fill the space between the pipe and the post with crushed stone.
sorry, I should have mentioned that the fence posts are square. I wondered about this. Do they make square extruded PVC pipe? – Evil Elf Aug 22 '12 at 12:59
It doesn't matter. You will have a small space from the curve in the pipe that you can fill in with crushed stone so that water won't collect in it. – mikes Aug 22 '12 at 23:50
I found these. I don't know how I found them or why I couldn't find them before.
http://www.rittenhouse.ca/asp/Product.asp?PG=9000536
