Tell me more ×
Why would a repairman install a 1/3 HP fan motor into a 1/5 HP unit? He had to cut the shaft to make it fit. Two weeks later unit quit again and then he had to come and replace the capacitor MFD (whatever that is). I found all this out from a different company's A/C tech when it quit again 2 months later (fan had also been put back in backwards and damaged).
Probably I should mention the original repairman tried to sell me a new A/C from the start, "when parts start to break it's time to replace the whole unit". When I told him our house was only 4 years old he said that's as long as they last sometimes.
closed as not constructive by Niall C., Steven, ChrisF Aug 20 '12 at 13:20
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or specific expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, see the FAQ for guidance.
1 Answer
Most likely because he had it on hand. Possibly leftover from an unrelated ordering error, so he was chuffed to use it in a chargeable account. If all the other characteristics were similar, there's nothing wrong using a somewhat oversized motor. It's a big IF though. For instance, the larger motor may have overloaded the starter circuit, frying the capacitor. No accusations here, this is pure conjecture.
No matter what, it should have lasted more than 2 months. It was either defective, or there's something inherently wrong with how it's installed that greatly shortens motor life. Backwards is a rather comical rookie mistake, easily caught if someone bothers to check their own work before leaving.
A pretty flippant comment that some units only last 4 years. He's somewhat correct in that a rare few units fail prematurely due to some defect in manufacture. But expected lifespan is quite a bit longer.
We might write this off as a fluke, but if you have another motor failure, an investigation for a contributory factor would be warranted.
"Backwards is a rather comical rookie mistake" just boils your blood thinking about the "pros" out there.. – ppumkin Aug 17 '12 at 11:30
