I'm seeing a new small hole on my hardwood floor since last week. It almost looks like it was a black spot before and then it became a hole. Is this because I didn't maintain the floor? or is it some sort of insect that did it?
It's likely a knot that came loose. The circular grain around it sure makes it look that way. The wood can turn blackish like this if water gets in there and sits which could easily have happened with a small hole like that. |
Clean out the loose or soft darkened area with a utility knife. Fill the hole with stainable wood filler that is close to the shade of the floor, such as this
After it dries, if you need to color it to blend in, try one of these markers.
If necessary, make it just barely darker than the surrounding wood. It will look like a small knot. The colors can be blended by putting small dots of diferent colors next to and over each other. Go slowly. Seal it with a touch of polyurethane with the same sheen as the rest of the floor (it looks like a satin finish in the picture). |
Black holes are caused by a massive body collapsing in on itself, creating a dense object with a gravitational field so strong that the escape velocity is greater than the speed of light. Or, a knot falls out. I'd drill out the dark matter around the hole, and fill it with a dowel to about 1/8 below the floor surface. Then I'd do my best finishing the top with wood filler. |
