Tell me more ×
BACKGROUND:
New house built 5 years ago. I have a basement theater room with 12 foot drywall ceilings that have HVAC conduit and recessed lighting (in other words there is some space behind/above the drywall). I have a projector I need to ceiling mount and a surround sound system to run front and rear speakers.
I plan to have the projector in the ceiling and the other electronics (receiver, etc) off to the side of the room on the ground (receiver cabinet). So I need to run power and HDMI from the receiver cabinet to the projector as well as speaker wire from the receiver cabinet to the four corners of the room. I have a 25 foot HDMI, speaker wire and an indoor/outdoor extension cord.
QUESTION:
My primary concern is how to run the HDMI and power to the projector. Should I run some sort of conduit or channel in the ceiling (exposed or hidden) -- like a server room runs ethernet cable? If behind the wall, is it safe/code to run an extension cord behind the drywall in the ceiling to power the projector?
I may run the speaker along the baseboard simply to avoid extensive wiring/holes in my ceiling so I'm less concerned about how to do that.
Do these questions solve your problem? Wiring a wall mounted HDTV and Fishing wire through ceiling – BMitch Aug 11 '12 at 13:03
And also: how do I run wires to a wall mounted HDTV – BMitch Aug 11 '12 at 13:06
1 Answer
up vote 4 down vote accepted
HDMI and speaker wire are basically signal wires, not power wires. Both the voltage and amperage is very low. Indoors it is safe to run these hidden or exposed without channel or conduit if they are properly rated. See this Q&A for a discussion of proper rating.
When channel or conduit is used, it is either for convenience in handling, and to keep the wires away from other materials, or it is used to improve the aesthetics - channel can be painted and looks neater than cables.
There are limits as to how much signal wire can be run in cable or conduit, but this is generally a function of pure physical space and ability to pull wire, rather than heat or safety. Speaker wire can be tacked to baseboards or other molding if that works. be careful to avoid breaking the insulation or the inner wires when stapling, and if you put wire under moldings, be careful not to nail through. Its not a danger issue, is a broken wire/no signal issue.
Power, including extensions to run a projector, is very different. No code allows extension cords to be buried in wall. I don't think any codes allow extensions to be tacked to baseboards. Also power cables should not run parallel to signal wires - they can cause interference even though many signal wires (like HDMI) are shielded.
You need to bring a regular, properly installed power line to the projector. This can be properly installed NM cable inside a wall to an outlet box. It can be surface wiring, but this requires standard metalic surface channels and boxes such as this and this:
wiremold wiremoldbox
One other note. Lampcord is often used as speaker wire. It is the same as is used for AC power cords and small extension cords. If you are using such wire, be careful, if you are burying in walls or stapling, that it is speaker wire rather than power carrying wire.
It is not just voltage and current ratings that are of concern -- the flame test rating of the cable is critical to prevent flame spread. This applies whether the cable is high or low voltage or even fiber optic. Flame test ratings are usually a code requirement or specified for UL rated wood-frame building assemblies (i.e. walls and ceilings). Your statement that "it is safe to run these hidden or exposed without channel or conduit" is incorrect. Installing a bare HDMI cable in ceiling without an appropriate flame test rating (as most if not all HDMI cables are) is dangerous. – alx9r Aug 12 '12 at 23:48
@user115232 - thanks for the info. edited and linked to your answer to correct. – bib Aug 13 '12 at 0:11
No problem. I think that's how this site is supposed to work. This permalink that jumps to the answer about flame test rated wiring is probably more useful for casual readers. – alx9r Aug 13 '12 at 0:52
This topic comes up enough that somebody ought to ask "what type of cable is safe/code to put inside walls and ceilings?" – alx9r Aug 13 '12 at 0:55
@user115232 - Relinked – bib Aug 13 '12 at 15:39
show 1 more comment
