Tell me more ×
My bathroom backsplash-to-wall junction was just re-caulked yesterday. (The old caulk was discolored and showing signs of mold.) But on one side of the countertop where there's a 3/8" gap between wall and backsplash, the new caulk was applied at a slightly lower level than the top of the backsplash, meaning there's a small area where water will pool on top of the caulk instead of draining back down onto the backsplash and countertop.
Question: can I just add more caulk on top of the now-dried other caulk, in order to raise the caulk level above the backsplash top so water will drain correctly? Or do I need to rip out all the caulk and start from scratch?
I'm using GE Max 5000 caulk if it matters.
give it 24 hours before touching up any little gaps – shirlock homes Aug 7 '12 at 21:56
1 Answer
Ideally it would be one continuous bead of caulking, however for 3/8" of a gap at the very top, you will probably be OK just adding a bit more caulking to fill it in. However, if you don't want to have to touch it again for a while--and considering the low cost and relative ease of applying it--I think I would be inclined to remove the existing bead and apply a new one that covers the entire length. That way you don't have to worry about water getting behind it.
