Tell me more ×
This morning I found myself locked out of my garage. My interior wall opener isn't working and neither is the remote. The light on the interior pad is out, suggesting a loss of power. Unfortunately, my fuse box is inside the garage, and I I have no way of entering unless I can disable the opener and manually open the door. How in the world can I do that?
Is there a window in the garage door itself? If not is there a blank section of interior house wall that abuts an interior wall in the garage and which has nothing on it on the garage side? – bib Aug 6 '12 at 0:10
no window, but yes, a blank interior wall abutting interior garage wall – Anita Aug 6 '12 at 19:11
Some models include a lock cylinder on the garagedoor. Typically it is in the top panel. Insert the key (hopefully you have it) and the lock should come out when turned. A length of cord will be attached to the back of the lock. Pulling the cord releases the door from the opener and allows it to be opened manually.
If your door doesn't have one of these I would install one when you you get the door open. – mikes Aug 5 '12 at 23:36
I did look for that keyhole when I read some other problem-solving tips, but I don't have one – Anita Aug 6 '12 at 19:12
There should be a release handle inside, near where the door is attached to the raising mechanism. It often has a wooden or plastic toggle handle. Pull it and the door will be freed from the raising trolley, and will then be able to be lifted manually on its rails.
Anita indicated they have no access inside of the garage, so they need a way to pull this from outside. – BMitch Aug 5 '12 at 23:06
I (foolishly) assumed there was an inside access and thought she couldn't figure out how to get her car in and out. A more careful reading would have clarified. – bib Aug 5 '12 at 23:59
yes, I can't get in at all. There is a 3-4 inch give on the left side of the garage door when I pull it; nothing gives on the right. Is possible to break the door free with sheer physical strength...not mine hahaha – Anita Aug 6 '12 at 19:14
Ok, Solved the problem. There are 4 bolts on the outside of the garage door, holding the opening mechanism to the door. I undid them and the coupling holding the opening mechanism to the door let go, and I was able to manually open the door. The culprit? I was sure the breaker couldn't be the problem, because everything else electrical in the house was working fine. When I looked at the box I immediately saw the flipped breaker...and the only circuit on it was the garage door. What caused the circuit to break on the garage door after 13 years, I'll never know...
I'm surprised you were able to remove those bolts from the outside, but glad you got in. I'd suggest installing an external manual release with a key and then replacing the bolts with something more secure. – BMitch Aug 9 '12 at 23:13
