The water radiators I have under each window are 50 years old, and I would like some new ones. They measure HxLxD 50x100x20 cm.
The new ones I would like should be as thin as possible.
I live in an apartment, so a thermostat needs to be mounted on it.
Question
Are there things to be aware of when buying radiators?
There are a number of companies that make very low profile radiators such as this one:
runtal radiator
There are several factors such as the type of system - steam, hot water; if steam, whether one pipe or two. You will also have to accomodate certain valves, so placement is an issue - piping through the wall or from the floor, whether you can accomodate valves in the wall, and how to access if you do.
Size is also a significant consideration and you need to determine how much area you need to replace a much more massive old radiator. While the new ones may be more efficient, you may need more surface area, depending on the overall demand for heat.
