I have a Lennox G12Q3-120-6 model furnace. Does anyone know if there's a way to manually run just the blower without heat?
There are no switches on the outside that I can see (other than the power cut-off), and the only 2 panels are only to be removed when servicing.
FYI - I want to be able to use my furnace blower to circulate air from my basement to my upstairs.
Does your thermostat not have a fan control? – Steven Jul 27 '12 at 0:35
All it has is a lever to change the target temperature. Is that something that is generally included on a thermostat? I've never seen one that has a built in fan control. – Pickle Jul 27 '12 at 3:55
Yes on most of them you can set the fan to either auto or on which keeps the fan running all the time.. – Steven Jul 27 '12 at 12:04
I'll have to look into that. I imagine an HVAC repairman would know? – Pickle Jul 27 '12 at 14:18
Yes a HVAC tech will definitely know, but installing a thermostat is really easy so I would definitely suggest it as a DIY project! – Steven Jul 27 '12 at 14:31
