I've got a respirator like this one:
I assume with the particulate filters (for dust) you just change them when they get hard to breathe through, but what about the organic vapor or chemical cartridges? How do you know when they need to be replaced?
I assume with the particulate filters (for dust) you just change them when they get hard to breathe through, but what about the organic vapor or chemical cartridges? How do you know when they need to be replaced? |
You are correct regarding the dust filters... in fact the "caking" particles can sometimes improve filtration... so the cartridges only need to be replaced when damaged, soiled or when they unacceptably obstruct breathing. As for chemical filters... this depends a great deal on the chemicals being dealt with, as each will have different properties. Each cartridge should have a specified service life or change schedule... nonetheless, for vapors and certain organic compounds 3M™ recommends that they be used for only a single shift exposure
