Tell me more ×
In one corner of my basement, after a few heavy rains, I see a darkening of the concrete floor. To touch, the concrete feels damp-ish. I say damp-ish, because when I pull my hand away, I don't see any moisture on it. There is also no beaded moisture on the surface.
The house is 57 years old, so I don't know if there is any drainage tile on the outside of the foundation.
Since the house is so old, it has settled and the surrounding landscape slopes towards the house - about 20' away has a 2-3 inch slope towards the house.
I believe the moisture is wicking up from the ground water, as there are no cracks in the foundation floor or basement walls.
Multi-part question here:
  1. Will backfilling and building a slope away from the house stop this or at least greatly reduce the problem? Or is this simply a matter of the water table being higher than the basement floor? I'll re-iterate that this problem is only in one corner of the house.
  2. I've only owned the house for 3 years, but it looks like this has been an issue for a number of years, with little real problems. Is this something I really need to worry about, or is it mostly cosmetic? The idea of "moisture in the basement" is typically a red flag, but since there's no beaded moisture, it's only in 1 corner, and there's no cracking on either the floor or walls, I'm wondering if this isn't a big deal.
  3. Should I bother to get a dehumidifier or sealant for the concrete? Is that typically what is done in this situation or will that just be a bandaid to a deeper problem with the concrete/fill under the basement floor?
Edit: Not sure if this is relevant, but this section of floor also has a drain pipe connected to, I'm guessing, the sewer. My washing machine drains to it, but I don't notice any correlation between washing & discolouration.
Sloping the ground AWAY from the house will always help. A dehumidifier doesn't do much for ground water, but is important if you live in a humid region to avoid condensation issues. An interior sealant won't do a whole lot. – DA01 Jul 25 '12 at 22:37
up vote 7 down vote accepted
Multi-part answer here:
  1. It could be the water table, in which case, there's not a lot you can do. If it's the water table, then you'll have water seeping up through the floor. BUT consider that when they built the house, they dug a bowl in the ground, and then backfilled with loose soil, rocks and whatever other garbage they had lying around. You could have a permeable (gravel and sand) fill inside a relatively impermeable bowl (clay). In this case, sloping the ground away can help. It will at least get rid of standing water up against the foundation and help mitigate anything flowing through the walls.
  2. The major worry is mold. Make sure the area is clean, so that there's nothing for mold to feed on. You can spray with a biocide if you see any growing, and certainly don't enclose it by adding drywall over the area.
  3. If you have rising damp, then an internal sealant won't do anything. the hydrostatic pressure will force water through. A dehumidifier will remove the symptoms.
(1) Because I'm not seeing any discolouration on the walls, I'm not sure there is water against the foundation. I'm not an expert though (obviously). One solution I've heard is drilling a hole in the basement floor, and putting in a sump pit. Will this cause more problems than it solves? It sounds like my 2 initial thoughts (backfill and a dehumidifier) will be sufficient to manage this issue. – Pickle Jul 25 '12 at 22:01
@pickle, if you can start with re-grading the earth near the foundation, I'd start there. ALong with fixing any gutter problems, it's likely the easiest issue to work on first. – DA01 Jul 25 '12 at 22:38
I sloped the surface away from the house about 1' to 2' in this corner of the house. Since the slope towards the house is due to settling, I wonder if I need to slope much further away to extend beyond the section of ground that has settled with the house, ex: gist.github.com/3179163 – Pickle Jul 25 '12 at 22:47
You should try to get at least a 5% slope away from the foundation for a distance of at least 5 feet. From there, there needs to be enough slope so there is no standing water during heavy rain. – bcworkz Jul 26 '12 at 2:48
Thanks @bcworkz. That helps clarify. – Pickle Jul 26 '12 at 15:21
I think Chris hit all the main points. Two other things I think are worth mentioning:
  1. Because you said there is a drainage pipe at the location of the dampness, it might be worth having your sewer inspected with a camera. It is possible that the sewer is collapsed, has a belly or is otherwise restricted at this location. If your house has a French drain that ties in here, it could cause the moisture. If your downspout is connected to your sewer and there is a restriction, this too could be a cause.
  2. Make sure that your eaves expel the water far away from your foundation. Even if the slope was good, if the water is being expelled right at the foundation, it will find a way in.
(1) This is something I'll consider. I haven't noticed any correlation between heavy sewer discharge (ie, showers or multiple washing machine loads) and the moisture though. I don't know if I have weeping tile. (2) The eaves/downspout all run off 30 feet away from the foundation. I fixed that last year and really noticed a drop in the amount my sump pump runs (down to not at all, and yes it does work). – Pickle Jul 25 '12 at 22:39
I've got the same problem and while my house is 150 years old, an addition with a brand new basement is new this year. I watched the contractor put at least 12 vertical feet of stone into the exterior perimeter of the entire new foundation wall. At the bottom of the exterior walls were multiple drain tiles intended to take the water away (how they work is a mystery to me as they are full of holes, but that's for another day). The problem is with the new peaks on the roof which come to an angle and collect the roof water and dump it straight down to the stone bed. I got a dehumidifier which registered 70% relative humidity when I started it running and am planning on getting gutters or some kind of control system to take the roof water elsewhere. We'll see.
Welcome to the site wmbrennan. Could you reformat this to be more of an answer to Pickle's question, rather than a description of your own problem? – BMitch Aug 4 '12 at 20:06
