Trying to replace a light bulb that has a mini candelabra base and want to replace this bulb with a CFL bulb but can't find any. Are CFLs available with mini candelabra bases?
closed as off topic by Niall C., ChrisF♦ Aug 15 '12 at 11:19
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
Sounds like you know what you want, an E-11 base CFL, not the more common E-12 sized base candelabra that Mr. Sherman linked to. Unfortunately, the mini term gets thrown around alot, referring to the over all size, not the base size. As you have found, E-11 CFLs are pretty rare, if they exist at all. However, you can get adapters that fit in E-11 sockets and accept E-12 based CFLs. Obviously they extend the height of the final installation, and some E-12 CFLs are fairly huge in the first place. However, if you look around, you can find E-12 CFLs that are reasonably sized, and even have something similar to the traditional candelabra shape. Happy searching :) |
I found the Sylvania Micro-Mini candelabra base to fit fine. The fluorescent corkscrew was also small enough to fit under my paddle fan's diffuser, unlike a couple other brands I tried. I found them at my local Lowes, picked them up with a few other options, tried them all out, and returned the ones that didn't fit. If these don't fit, it's possible you're out of luck. |
