Sign up ×
I am building a yard barn/shed, that uses cedar posts as the outside framing of the gable ends.
SketchUp model of barn
I was planning on just drilling and lag-bolting the posts together (plugging the holes) but do you think I should glue them as well?
up vote 3 down vote accepted
Gluing won't hurt, but it won't help either (in this application) so I wouldn't bother.
Where gluing does help is when you are doubling a beam by stacking two smaller beams on top of each other. (i.e. 2 2x4's to make a 2x8) Gluing will then help transfer the longitudinal shear stresses that develop when the beam bends slightly. (To visualize this shear, bend a paperback book, and see how the pages slide against each other.)
Glue works best to keep things from sliding against each other. It's worse in a torque scenario, where you would try to twist two pieces apart, and not very good in tension. It's also completely unnecessary in compression.
Thanks Chris, that makes sense. My worry is longitudal rafter load in the winter, and wind. It sounds like glue will not add any strength. – Matt Dowell Jul 20 '12 at 20:55
