Tell me more ×
I need help confirming what size of screws, spacer and drillbit to use for installation of a shelf in my kitchen. Some specifics:
  • shelf is 200 x 30 x 1.8cm (spruce).
  • shelf brackets ask for 4mm screw.
  • using special drillbit as I will be screwing the shelf bracket into kitchen backsplash tiles.
  • backsplash is installed on solid wall, so I am not dealing with studs if that makes any difference.
I have tested the drillbit on a test piece of tile and am comfortable with the technique (ie, placing tape in an X) and the feel of the drillbit on the tile. My questions pertain to choosing the correct bracket, screws and spacers to ensure that the whole thing doesn't come crumbling down at some point.
As I noted above, the brackets call for a 4mm screw, and each bracket has a 50kg sign on it (I'm in Europe), but I'm uncertain if this means per bracket, or per set of 4 brackets? Given that this is going into a tile and is meant to hold a 200cm (200 x 30 x 1.8 cm) shelf, What length of screw should I use? Will a 4mm screw be sufficient? And how many of the brackets should I install (ie, what distance between each bracket - one at 10cm, 70cm, 130cm, 190cm - or will I be fine with 3 - 10 cm, 100 cm, 190 cm)?
Any other tips / suggestions please?
Thank you
What do you mean when you say "solid wall"? – bib Jul 17 '12 at 19:15
Thank you for responding. It's a plaster wall. There's no drywall or anything. – receipt Jul 17 '12 at 19:28
1 Answer
up vote 2 down vote accepted
Perhaps more important than the size of the screws (or other fasteners) is what they actually grasp. With any significant load, a screw will not hold by itself in tile or plaster. The tile will chip and the plaster will crumble.
One possibility is to use an anchor through the tile and plaster that expands laterally. There are several types (plastic, metal, etc.), but these are also generally used for lighter loads that are close to the wall, not a shelf that sits on brackets that act like levers, tending to pull them through the wall:
plastic anchor
If your plaster is attached directly to masonry, there is an expanding anchor that is meant for that:
lag anchor
It must be placed in the masonry, not the plaster.
If there is a hollow space behind the plaster, a third type of anchor that mushrooms behind the surface could be used:
mushroom anchor
A fourth kind is a toggle that is inserted folded, but then opens behind the surface of the plaster and its fastening:
toggle1
toggle2
If the wall behind the plaster is hollow, this may be the best type of fastener.
If there are studs behind the plaster, the strongest fastening is to align the brackets with the studs and go through both the backsplash, plaster and finally into the studs with wood screws (wooden studs) or screws designed for metal studs.
Thanks kindly for the detailed response, bib, I appreciate it. Unfortunately, I'm not sure if any of these will work as the wall is completely solid with there being no indication that there's anything remotely accessible (studs or hollow space). This is a flat in an old German Altbau building from 1905, so this is quite common. When we arrived in the flat there was a very heavy beam placed along the same wall, so I'm fairly confident it is a relatively sturdy wall. But you think that regular plastic spacers would be insufficient? – receipt Jul 17 '12 at 20:46
I would be very wary of plactic anchors. If it seems solid behind the plaster, probably some type of masonry and you can use expanding masonry anchors. Test by drilling beyond the plaster (and any thin wood that may be attached to it) to see what is behind it. Red probably means brick. Grey may be stone or concrete. Stone is much harder and you would know when you try to drill. You need a masonry type drill and would do better with a hammer drill (it has a forward impact as well as a rotary motion) if that is the case. The drilling is demanding, but to be safe, I would go that route. – bib Jul 17 '12 at 21:01
