Tell me more ×
Removing old carpet resulted in about 1 inch gap between doors and the floor. What are common solutions to cover such gap? Any "easy to handle" materials (other than wood planks) to extend doors?
up vote 1 down vote accepted
I think the easiest thing to do would be to install some weather stripping to cover the gap. I realize it's indoors but this will be easy to install and work with, and will accomplish your goal. Something like this:
Weather Stripping
It's hard to see from the picture, is this a foam based? How it is attached? OK, I guess I'd have to search for "weather stripping" at Home Depot.. Thanks! – sasha Jul 17 '12 at 20:26
It has rubber at the bottom. It attaches with a couple screws into the door – Steven Jul 17 '12 at 20:32
The most common solution is to add "wood planks" to the floor, not the door. These are called saddles. They are specialized moldings, usually about 3 to 6 inches wide with tapered edges. The usually are 1/2 to 3/4 inches thick. They are centered under the door and reduce airflow and noise.
These are most commonly available in unfinished oak or pine:
saddle
They also can be found in other woods, prefinished, or matched to a floor system:
