I've purchased this cabinet recently and would like to know if there is a way to paint it white?
It is described as:
Frame Material: Hardwood
Wood Finish: Painted
Finish: Painted
I've purchased this cabinet recently and would like to know if there is a way to paint it white? It is described as:
Remove the doors and all hardware, if you can remove the glass that is even better; if not just mask the glass. Take a fine grit sandpaper like 320 and sand everything that is black to scuff up the finish (you don't want to paint on a finish). Get a few cans of white spray paint in whatever finish you want and start spaying. In multiple light coats allowing time to dry between coats and in a well ventilated area. Most paints nowadays spays included shouldn't need a primer. |
