It seems something has happened to my dishwasher so I can now only open the door halfway, before it starts jamming.
The wooden facia on the front of the door is unaligned by a centimeter or two, meaning the facia jams against the surrounding cupboard units
If I peek through the gap between the facia and the dishwasher front, I can see some sort of metal bracket, but I dont know how to remove or realign the facia.
Any ideas please? Sorry if its a bad description, its kinda a weird problem which happened while I was away from home for a week
Find the manual for your appliance, it will provide instructions on how the panel mounts to the dishwasher – Steven Jul 9 '12 at 13:53
Its an OKO Favorit (it appears OKO is a foreign name for AEG). I've viewed a few manuals for OKO Favorit, but none of them mention anything about the facia. I cannot find the exact model number I have, but Ive a sneaking suspicion it might be on a label underneath the facia. So back to square one. I was hoping these integrated dishwashers had some sort of standard way of fitting though – carpii Jul 9 '12 at 21:05
We could only wish they were standard :) If it helps, on my dishwasher, on the inside of the door, there are 3 screws on each side which are used to secure the door panel – Steven Jul 9 '12 at 22:05
Thanks Steven, Ill look for some screws on inside. But I had a real job even squeezing a clean fork out the dishwasher, so if the screws are anywhere near the base of the door, I think Im in trouble :) – carpii Jul 10 '12 at 1:20
Have you tried forcing the door panel back to the correct position? – Steven Jul 10 '12 at 1:45
up vote 1 down vote accepted
If it was moved out of alignment, you should be able to move it back into the correct alignment to allow you to open the dishwasher door again.
If you cannot get a decent grip on the door sides to force it, you can try using a glass suction cup to get a hold of it and force it back into position.
Glass Suction Cup
its a wooden door front rather than glass. The problem is whilst I can grab the door facia, the manouvre I need to make to get it back into position isnt obvious. Thanks for the advice though, Im thinking I cant explain it well enough (and its too obscure a problem) for it be sorted over the net – carpii Jul 11 '12 at 1:09
You can use this on any surface really, it's not limited to glass – Steven Jul 11 '12 at 1:17
I finally got to the bottom of the problem. What has happened is the stopcock under my kitchen sink has been dripping while I was away. This meant the cupboard adjacent to the dishwasher became soaked, and swelled up. This caused the dishwasher door to start jamming against the side of it when opening – carpii Jul 15 '12 at 0:22
But then it gets worse. In my attempts to force the door open, it pulled the dishwasher forward slightly, and the 4 plastic legs which the dishwasher was raised up on, snapped clean off. Of course this wasnt that obvious at the time, because its all hidden behind kick plates. – carpii Jul 15 '12 at 0:24
Finally, Im marking your answer as correct, because as it turns out, nobody could have helped me over the net, but I appreciate you at least trying :-) Thanks – carpii Jul 15 '12 at 0:24
