I just want to make sure this wont hurt anything.
Right before I bought this house, it got a new AC and furnace but they did not replace much of the duct work. This vent is right above the AC unit and is the first vent the cold air passes. It was bleeding cold air into the basement so I covered it.
You probably want at least one vent down there, but yea, probably not there. Also note that duct tape is (ironically) not designed for ducts. – DA01 Jul 5 '12 at 17:37
up vote 7 down vote accepted
Whether you tape it or otherwise block it, the effect will be the same and it will not cause any damage to your system; it would be no different than if there was a standard register there that was closed.
The only thing I'll note is that duct tape will eventually dry up and fall off. Ideally you would use foil HVAC tape
HVAC Tape
Unlike duct tape, this will not dry up and will hold the seal.
Thanks. I was planning on getting some foil tape (as long as I got no feed back on this damaging the system) this weekend. But at 103 outside I just grabbed the first thing I saw – zk. Jul 5 '12 at 18:53
