I just bought a leviton GFCI and the instructions say if there are two load lines in the box, do not connect the GFCI in that box. I can't understand why this is a problem, especially since the device has holes for two sets of wires (plus screw terminals) on the load side. Is this an issue of GFCI volume vs box size?
This a kitchen outlet; my alternative would be to cut into the supply line & put the GFCI there, but this would be in the basement and inconvenient.
