Tell me more ×
I am in the process of purchasing a home. I found the perfect home but of course, I found water stains in the basement walls (mostly close to the floor). I also noticed a small hole at the corner of the foundation, about 2 to 3 inches in diameterCan this be the cause of the water seepage in the basement ? How can it be fixed.
Thank you for the reply. I took a picture and tried to post but won't let me cause I don't have reputation. The sump pump is on the opposite side of the house. The hole is close to another pipe.
Did you take a picture that you can post? – DaveNay Jun 27 '12 at 3:41
Have you hired an inspector yet? If not, absolutely do that. Never buy a home without first having it inspected. This is a question you need to ask the inspector. – DA01 Jun 28 '12 at 5:13
1 Answer
You may want to ask whether the hole is for a sump pump that removes water from the basement in wet weather - it could exist specifically to prevent further water issues (such as the one that caused the water marks) in the basement, in which case, filling it in would be inadvisable.
If the sump is simply dumping water right out the foundation, it's going to have to work a lot harder since all the water it pumps out will come right back in. – Tester101 Jun 27 '12 at 16:17
