Tell me more ×
The lights on my harbor breeze fan stopped working this morning. When I came home from work, I got the ladder and took down the lights. I don't have a multimeter but I saw that there is this Watt Regulator (pic below) in the fan. I traced the wires and it seems that this may have been the culprit. I snipped the wires, got some wire nuts, and wired directly into the 120V circuit. Ta-da! Lights are back and fan is working normal.
Question is : What is the purpose of this watt regulator? Why do some fans include it?
alt text
Can you post a pic of this where the label is legible? – Mike Powell Aug 27 '10 at 15:12
@Mike: I'll have to try. It says "120V 300W MAX" by Hunter. Part Number 98480-02 Hunter. UL certification here: google.com/… – 0A0D Aug 27 '10 at 19:11
See comment on Mike Powell's answer. – Tester101 Oct 5 '10 at 16:36
I should add that a year later, this fan is still working great w/o the regulator. – 0A0D Aug 28 '11 at 23:48
Thanks so much for the info I almost gave 49.95 to replace the part i did not need, now that i bypassed it it works just fine and the way they installed it you can bypass it with no tools just hook the two whites together and then the other two together the electrical ends are made for this to work – user4036 Oct 15 '11 at 17:54
show 2 more comments
up vote 3 down vote accepted
A regulator would normally be used either to change the speed of the fan or the brightness of the lights. If this regulator didn't have any external controls like a pull chain, is there a chance this fan at one time had a remote control?
brand new fan.. did not come with a remote control. I just installed it about a month ago – 0A0D Aug 27 '10 at 11:06
It's possible that this model and a more pricey model are both manufactured at the same time. The only difference being the more expensive fan gets an RF receiver to control the regulator and this one does not. This is common practice in manufacturing, and possibly the reason the fan has "extra" parts. It's even possible that this model is ready for a remote, they just did not include one and charged less because of it. This might also explain why the lights stopped working, if something was on the same frequency it could have turned them off. – Tester101 Oct 5 '10 at 16:31
Here's the real story:
http://www1.eere.energy.gov/buildings/appliance_standards/residential/ceiling_fans.html
As required by the Energy Policy Act of 2005 (EPACT 2005), the U.S. Department of Energy (DOE) has established test procedures and energy conservation standards for ceiling fans and for ceiling fan light kits.
Ceiling fan light kits with any other socket type including but not limited to candelabra screw base sockets, intermediate screw-base sockets, 2-pin halogen sockets, and bayonet sockets manufactured on or after January 1, 2009, shall not be capable of operating with lamps that total more than 190 watts and must be packaged with lamps that together total 190 watts or less. DOE indicated in a January 11, 2007, final rule that it recognizes that manufacturers may choose to follow one of several possible design pathways to ensure that the light kit is not capable of operating with lamps that total more than 190 watts.
+1 for referencing the (somewhat silly) regulation. I'm a little confused as to why the device in question would be labeled MAX 300W if the regs require less than 190W of lighting – mac Nov 29 '12 at 15:21
Welcome to the USSA. – Kaz Apr 1 at 6:53
The Wattage regulator has nothing to do with speed of fan or brightness of bulbs or for a remote. It is a safety feature that prevents the fan from overheating. If you install bulbs that exceed the specified wattage, the wattage regulator either shuts off the bulbs or limits the wattage they receive to prevent overheating. Contact the manufacturer and they should send you a new light kit.
still doesn't make sense because I use CFLs which are low wattage. – 0A0D Aug 6 '12 at 17:44
protected by Community 6 hours ago
This question is protected to prevent "thanks!", "me too!", or spam answers by new users. To answer it, you must have earned at least 10 reputation on this site.
