Tell me more ×
There's a water leak in the tube coming out of my heater. Yet the bolts look tightly put.
water leak
I'm not sure how to fix it. Any idea ?
Looks to me like a compression fitting, which probably has a grommet, o-ring or seal inside, and that is probably the part that's leaking (due to the design, the tightness doesn't matter too much and actually too tight can damage the grommet). I can't provide a real answer though as I don't know anything about radiant heaters (eg if that is some specific specialized part) or how you can drain/isolate that without flooding your house, etc. – gregmac Jun 20 '12 at 21:33
1 Answer
up vote 5 down vote accepted
The first thing to do is verify where the leak is occuring. It could be occuring higher up and just dripping from the fitting (though it is very likely that it is the fitting leaking). Dry the entire pipe off and then watch for water.
Assuming it is the compression fitting, the first thing I'd try is tightening it by 1/8 to 1/4 of a turn. As gregmac mentioned in the comment, over tightening a compression fitting can damage it and cause leaks. It could be that it is already over tightened in which case the damage is already done.
If this does not help you will likely need to replace the fitting. I can't see what is above the compression fitting so I don't know if it can be replaced by itself. There might also be damage (either corrosion, or just from the compression fitting being too tight) to the pipe where it meets the fitting in which case you'd have to replace a portion of the pipe too.
I would also be inclined to peel that tape off to see what it is covering. If there are pinhole leaks this can indicate an electrical grounding issue.
Thx, will do that – drake035 Jun 22 '12 at 20:58
