Tell me more ×
I need this made of nylon to cut through adhesive without damaging surrounding surfaces.
saw blade
If you explain what you're trying to do, someone may be able to offer another solution as well. Pictures are very useful. – gregmac Jun 17 '12 at 21:01
The adhesive is significantly weaker than the surrounding materials? I'm not sure the end goal here. Regardless of what the blade is made out of, it is designed to remove the material it is contact with. It shouldn't be harming anything outside the cut. – DA01 Jun 17 '12 at 22:10
Have you tried 3M™ General Purpose Adhesive Remover? – Tester101 Jun 18 '12 at 16:25
How about using a heat gun to soften it up? – Steven Jun 18 '12 at 20:42
closed as not a real question by DA01, BMitch, Steven, Tester101, ChrisF Jun 24 '12 at 11:16
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
