Tell me more ×
We bought new house and I need to test network (RJ45) and coax jacks to see which ones are working. How can I do that without actually connecting computers/cable boxes?
Personally, I would abandon using network cables in the house, if possible, and use a powerline network adapter. That is the modern way of doing it. Use network cables only in situations where it might look nicer than a powerline adapter sitting in a electrical socket. – djangofan Jun 18 '12 at 21:32
1 Answer
up vote 8 down vote accepted
Very good question but you need to find out more information.
The very first question on my mind is.. Where do they connect to ? if they are connected to anything else at all?
The solution
Find the starting point(A) and the end point(B) of either cable.
Using a multimeter and a return cable you test continuity of the cable. Either using Ohms = 0 which means short circuit(in this case good because the cable is good) or some meters have buzzer if there is continuity.
  • To "TEST" if the cable is OK to work with
RJ45 Netw4rok cable used for 10/100Base Networks.
This is very time consuming because RJ45 have several strands of cable so testing one after the other can be beach. But one clever solution is to make a loopback on point B and test the correspoding points on PointA. If any one does not loop back then the cable is most likely broken.
There are also network testing equipment that do the same as mentioned above.. but you have nice flashy lights and a nice loopback box supplied.Ebay a few bucks each for el cheapo ones.
COAX
Coax is a funny one and depending on what you need it for. Coax for TV, satellite or CCTV again. just test using a multi meter test the two end points. Center to Center and Shield to Shield. An extra step here is to test for short circuit between singal(centre) and shield) so just on one end using ohm, test center and shield and you should have NO reading(not 0ohm0just nothing) If you get a reading at all you will get interference and the cable is likely to be damaged or unusable.
The other part if its used for a network then it all has to be connected and terminated to test it(but its unlikely its used for network because these types or network have been eradicated because of unreliability)
REMEMBER
This will only test if the cables are in an operable state. So you connect it and it will work. The bandwidth, noise-to-signal and interference will greatly depend on the quality of the cable, workmanship during installations, etc.
EG The RJ45 could be rated for Gigabit but your bandwidth could a mere 250mbs(1/4 bandwidth) because the shielding has not been done properly, or the ends have been poorly installed, the cable is near high voltage lines, the cable is severely bent ins several places along the way.
COAX in general either works or not.But for Analog Video; again many factors come into play. For digital(eg satellites) it should be ok
Not sure how long your multimeter leads are, but mine are definitely not long enough to reach from an upstairs bedroom to a basement patch panel... You can still test those with a multi-meter though, using a coax (75ohm) terminator. Screw the terminator onto one end, and at the other end use your multimeter: you should see 75ohms (plus some loss for cable length) center to shield. – gregmac Jun 14 '12 at 14:44
You not sure how long? Mine are as long as any standard one :-) But i tend to have some extra single strand of cable to help test continuity..so you would need a length of cable to help you(or make a loopback- if it loops back then both wires are OK. if it does not 1 is broken.. then you need continuity testing with a long cable). I think I mentioned using an extra cable in the answer though? – ppumkin Jun 14 '12 at 14:50
Thank you, this is very helpful! – sergeb Jun 14 '12 at 15:01
