Tell me more ×
I've used it in a boat-building workshop, but I'm not clear on what "doorskin" is. Is it just plywood made of a single ply? What is its intended purpose? Is it sold at building supply stores that have plywood?
The one suggestion I've seen for DIY house work is to use it when building a ripping guide for a circular saw. You attach a reliable straightedge (like a factory-edged strip of plywood) to a piece of doorskin, then cut the doorskin with a saw. The reason for using doorskin is that you don't lose much of the cutting depth of the saw blade.
I tried Google, Wikipedia, homedepot.com, and lowes.com, and couldn't find it. Maybe my google-fu is weak today.
if it is thin ply, Luan might work. – DA01 Jun 13 '12 at 15:34
Get that dusty disco ball out and fire it up. That'll keep those evil anti-google kewpie demons away! – lqlarry Jun 14 '12 at 0:56
1 Answer
I would imagine that it is luan sheets. Luan is used to 'skin' hollow core doors. It can also be used in other applications as a 'skin' when trying to create a light rigid platform with an internal skeleton of framework(much like a hollow core door or assembly table)
ding ding ding we have a winner! Just like it sounds. – lqlarry Jun 14 '12 at 0:54
