I want to remove a rock wall behind my pellet stove that was put in in 1980.
I have already removed some of the rock and cement that holds the rocks together where the pellet stove is sitting. Then I wet swiffered it all and put everything in bags outside and put all clothes in washer and took a shower. But I did not put on a mask or anything.
I do remember when my mother and I put this wall and pedestal up in 1980, my dad first installed some kind of backerboard?? that was a grey color that we attached the rock and cement to. This is what I am wondering if it might have asbestos in. I have pictures somewhere of us putting up the rocks and we did wear the simple white masks that people will wear when they paint or something because it was a dirty job (we added a black powder coloring to the cement mortar).
I think the backerboard could be removed in two entire pieces once the rocks and mortar are pulled down and hopefully the board wouldn't have to be sawed or anything. Everything that I have read says that the asbestos "stuff" was still being used in the "early 80's". This doesn't help me much. It is an easy enough job that someone would not have to be hired and this is why I am questioning the asbestos issue. Also, is there a chance of asbestos being in the mortar in 1980? Because I could even have someone pull down the rocks and mortar if there would be no asbestos in the mortar, and then hire someone to come in and pull down the backerboard if there was a possibility of asbestos in it. Right? Or am I looking at this incorrectly?
If I am instructed to have the mortar and backerboard tested, how do I go about doing this? Where do I go and does this mean I have to saw a chunk out of the 5X8 piece of backerboard or take one entire piece in to be tested? If I have to take the entire piece in to be tested, do I need to have someone take it who is an asbestos expert?
There is no safe minimum exposure level for asbestos. Any amount of asbestos is dangerous. Even if there is no asbestos the cement dust is not good for you either. That said the primary concern is limiting and containing the dust. Seal off the room if possible, wear a respirator(they are available at the big box stores for under 25 bucks). Wet everything down with water to minimize the dust. Wear a set of disposable coveralls and throw them away when your done with the clean up. Don't use a shop vac to clean up the debris as the dust will pass thru the filter and be blown everywhere.
That's technically true in the same way as there's no safe exposure level for cigarrettes. But there's a world of difference between smoking a few cigarrettes in highschool vs. a 2-pack-a-day habit into your 30s just as there's a world of difference between remodeling a corner of your house vs. working in the asbestos industry for 30 years. (But certainly take safety precautions, of course) – DA01 Jun 12 '12 at 2:32
While your answer offers good tips for safely working with asbestos, it doesn't provide any information on how to determine if you're dealing with asbestos in the first place. How should a homeowner/DIYer determine if asbestos is present, before they start a project like this? – Tester101 Jun 12 '12 at 17:05
To test for asbestos, you take small parts of the material and take it to (or ship it to) a testing lab. Most major metropolitan areas will have testing labs.
Remember that Asbestos is only really dangerous in high quantities, and even then, only in it's 'friable' state (meaning easily turned to dust).
If you're demo-ing a small part of your own house, odds are slim that any harm will come to you. But it wouldn't hurt to take precautions, of course. I'd suggest getting a proper mask (one rated for asbestos), a HEPA filter for your dust collection vac and wet everything down as much as you can before and during the demo process.
UPDATE:
Some of these other answers are a bit overly dramatic, IMHO. Asbestos isn't universally deadly. In fact, in many cases where you might find and remove it in a home, the actual danger to you is minimal--especially if you practice even the most rudimentary safety precautions (keep the material wet, use a HEPA filter on the shop vac, etc.)
Of course, everyone has to do their own research and come to their own conclusions. But to balance the FUD a bit, here's a bit of quoted information from this site:
http://www.naturalhandyman.com/iip/infsisters/infasbestos.html
Asbestos a not a single, easily categorized substance such as carbon monoxide or radon. It occurs in a number of different forms and the risks posed by them vary considerably... from minimal to severe. Crocidolite and amosite asbestos, known as amphibole asbestos, are the most dangerous forms. Their fibers cling tenaciously to lung tissue while resisting the body's natural self-cleaning processes. This long term irritation to body tissue can lead to disease and death. Fortunately, these forms of asbestos have been banned for years though some may still exist in older homes.
Chrysotile asbestos, a less toxic form, comprises over 90% of all the asbestos used in the US. This form of asbestos is not nearly as persistent in lung tissue and low level intermittent exposure is not considered to be a health risk to a healthy person.
In fact, both OSHA and the EPA concur that asbestos is not dangerous unless airborne.
Even if airborne, many studies of asbestos workers indicate that it takes more than a casual exposure to asbestos dust to cause disease... even over periods as long as 15 to 30 years! Asbestos doesn't "radiate" danger and its mere existence in low levels in your environment is not automatically cause for alarm.
Just my opinion, but I think the stress caused by irrational asbestos fears would cause more health problems than any actual low-level exposure by a DIYer. ;)
While I agree the dangers of asbestos may be overly dramatized, keep in mind that some areas may have laws in place to control asbestos removal. Also remember that if you don't dispose of the asbestos properly, you could be putting other people at risk. – Tester101 Jun 12 '12 at 16:54
And let us not forget that (in the US at least) the danger level of a product or procedure, is often directly proportional to the settlements payed out due to lawsuits. – Tester101 Jun 12 '12 at 17:00
That is true. Do research laws. But note that a lot of areas have actually expanded DIY remidiation options as well. For instance, in MN, you are allowed to dispose of small quantities yourself in the regular garbage. It will vary from jurisdiction to jurisdiction, of course. – DA01 Jun 12 '12 at 18:25
While the EPA didn't officially ban the use of asbestos completely until 1989, it was used in pretty minor quantities and the health effects were already well understood by that point.
http://en.wikipedia.org/wiki/Asbestos#1960s.E2.80.931980s
Back then they would sometimes use Asbestos or horse hair as a binding agent in mortar. The amount that would exist though is very small but you don't want to mess around with this stuff so you are much better off to take a sample and have it tested just to be safe.
This answer provides some good information, however, it doesn't answer the OPs question 'How do I test for asbestos?'. – Tester101 Jun 12 '12 at 17:11
Since this is a moving target question, let's address that target.
Personally, I'd suggest that you just assume it was asbestos. Asbestos is NOT extremely dangerous, as some seem to think. it isn't radioactive, or a deadly toxin, or even worth laying awake at night and worrying about. It's a material composed of very light and very sharp little fibers. It's about 10-20x Worse than fiberglass to breathe or handle.
There are various methods of testing for it, none of which require the presence of actual scientists, an exotic chemical lab or anything more sophisticated than a decent microscope or high powered magnifying glass and a rudimentary understanding of what the word fiber means. This method might give a high level of false positives, but that's OK.
Wear a face mask. Taking a very small sample of the material (pea sized), soak it in water for a few minutes and then crush it with pliers to expose fresh surface area.
Note: You have just rendered the material friable, which (according to certain java programmers who have never actually done asbestos abatement) means that you have put yourself, your dog and anyone within a 50 block radius in risk of imminent cancer and possible jail time. It's not true, but try not to breathe the stuff. If we were doing an STM asbestos composition test, we'd need a lot of time and extra equipment while we analyzed the actual composition.
Place the crushed sample on the slide and illuminate it with a strong light from the side so that light reflects into the tube. It may take some finesse. Really, you should use a polarization kit, but that would take two or three paragraphs to explain. Most "contractors that know asbestos" just look at the stuff with a magnifying glass, and they do OK. You probably can't tell mica from mohair, so err on the safe side by assuming that anything with small flakes or is fibrous might contain asbestos.
As the water evaporates, you will see the composition of the material in finer detail. Look for fibrous material that reflects the light slightly, as if it were made of small bits of fish scale. If the material appears to be very large - like a bit of thread, it probably isn't asbestos. However, if it appears to be made of very fine threads or flakes, it might be.
You can look at a crushed bit of drywall and a crushed bit of cement for comparison. Don't forget that you could pay $30-$100 locally to get this done, or even purchase a kit from amazon to send it into a lab. It's an excellent way to drag the project out for weeks and pay several hundred dollars to a licensed contractor for removal, which always makes professionals happy
Asbestos is not uranium. You have to work pretty hard to get it to kill you, and that means getting a substantial amount into your body. I won't address your body's immune system response, but I'll explain why asbestos can mess you up. It's pointy and sharp, and living cells hate that!
There are six different minerals (amosite, chrysotile, crocidolite, and fibrous varieties of tremolite, actinolite, and anthophyllite) that are usually called asbestos. It occurs naturally in the environment, and the odds are good that you have quite a bit of it in your yard right now. It's fibrous, and that means it disintegrates into little threads that you might not even be able to see.
Even if you get enough of it into your body, it can take years before bad things happen enough to be noticeable. Your body will defend against these particles pretty well by trying to encapsulate and expel them. Since the particles are very sharp and light, your body won't do the best job of cleaning you out, and thus a certain amount of the substance will stick around and interfere with your immune system.
The CDC doesn't know if it causes birth defects, as there is no proof of this, anecdotal or otherwise. There are two types of cancer caused by exposure to asbestos: lung cancer and mesothelioma. You can get these from breathing dust and fiber of any kind, not just from asbestos. Smoking will guarantee it.
Also, Asbestos must be rendered “friable” to be considered hazardous. Friable asbestos fibers are those which can potentially be released into the air. Busting up backer board could do this, but not much. Try to take it out in big pieces and keep it wet, wet, wet until it's in the bag. The risk is close to nil if you wear protective clothing and keep it wet.
We don't know how much you need to accumulate in your lungs to cause long term problems. It appears to be much more than a day or two of having the dust around, but all of the linkage studies involved people who had many months of continuous exposure.
There are three ways to start accumulating it: You can ingest it, you can get it into your epidermis or other membranes and worst of all, you can breath it and get it into your lungs. As long as you address all three of these routes of contact (and arrange for proper disposal of the removed waste) you have little to worry about.
I'll assume you're bright enough to realize that you should wear protective clothes made of closely woven materials and gloves, and that you'll put cloth booties on, and remember to cover up your face, ears, and neck.
Asbestos fibers do not evaporate into air or dissolve in water, and Asbestos fibers and particles may remain suspended in the air for a long time. this is why I add soap to my spray bottles - the soap solution will coat and cling to the fibers so that after the water evaporates, the fibers are heavier than before and will not float for as long.
In many cases, the trained professionals you want to rely on are $10 an hour off the street temp labor with 30 minutes of training, a $15 disposable plastic suit with hood (you can buy these at any pro paint store), a pair of booties and a cartridge type face mask. There is no secret to this process - just don't breathe it, get it on your eyes or skin, or actually swallow it. And they'll use blunt force (a term normally reserved for human injuries by the way) and chisel it off your wall, just like you would if you did it yourself.
All of the horror stories about asbestos are from people who had long term exposure - mechanics, workers, miners and people who lived in places where asbestos blows naturally in the air, or had been flaking from tiles or pipes for many years such as school kids and teachers.
This is important to know - because plaster dust (drywall, plaster walls), rock wool/insulation materials and concrete/stone dust is just as bad for you and your lungs as asbestos fibers are. For more than a hundred years people have done this kind of demolition (and suffered similar effects from inhaling similarly shaped fiber particulates) and yet no one bothers to call in the professionals for these things - even though you should be taking the exact same precautions.
Here's the money shot: Not a single case of cancer has been attributed to someone who pulled out two 4x8' pieces of cementious backer board from a wood stove installation over a couple of days. Not one. I suppose if you crumbled it up into gravel and left it laying around in a pile or scattered it throughout your house, you might have a problem.
If you were removing asbestos wraps from pipe or doing demolition of a sizable area, it might be a big deal. Pulling two small sheets of circa 1980s cement backer board down, (even if the manufacturer added a bit of asbestos to the mix) isn't going to be even close to risky - and certainly not compared to pulling wallboard and/or mortar down without a mask.
OSHA allows - actually states it won't be concerned about - up to 100,000 fibers per meter of air at a workplace before they get concerned. The EPA says that you can drink water with 7 million fibers per liter, but currently allows much more in residential sources.
The prudent course of action is to assume that it is asbestos containing material, unless you have access to a polarized light microscope and/or want to send it off to a lab to be tested. Even if it isn't, you should take the same precautions. This is a two hour job. Put on your protective gear, cover up the place, wet it and get rid of it. When you're done, wet wipe everything once again with soapy water, then with clean water. Then forget about it.
But seriously, wear a mask. And some gloves.
It is true that most cases of mesothelioma are from people who worked with it, but just like with cigarettes, your risk begins at even small occasional exposure. People who do abatement for a living are professionals who are highly experienced at doing this with multiple failsafes and cannot be replaced safely by some idiot drunk neighbors who will likely be sloppy. Even suggesting that you exploit an idiot by putting him in danger like that is deserving of a downvote. There are a few things that should simply NEVER be DIY and asbestos abatement is one of them. – maple_shaft Jun 12 '12 at 13:42
I disagree with the statement that asbestos removal should never be DIY. There's a lot of FUD when it comes to asbestos. A homeowner can often remove various types of material with asbestos with very minimal risk even when they are being careless. It's not plutonium we're talking about here. – DA01 Jun 12 '12 at 15:16
@DA01 If the removal requires cutting or blunt force of any kind then you really should call an abatement company. If you decide to do this yourself then you should be highly aware of the risks. – maple_shaft Jun 12 '12 at 15:36
"If you decide to do this yourself then you should be highly aware of the risks." = I completely agree! – DA01 Jun 12 '12 at 15:40
@maple_shaft Some numbers would be nice... Benzene is also a substance with no safe exposure limit, yet the EPA allows 5ppb of it in the drinking water. Without numbers, this discussion is meaningless. Standing outside your house increases the chances that you die from being hit by a stray bullet, but is the risk high enough to call in a professional to do your shopping? – romkyns Sep 26 '13 at 18:24
