Tell me more ×
I have a modern external light fixture that needs to be attached to an existing exterior electrical 'box'. The older parts of the house have knob & tube wiring and there is evidence of gas plumbing for lighting before the knob & tube was installed. Here, i think but am not certain, it appears as if the knob & tube comes into a 'box' around an old gas line (see photo) but I may be mistaken.
The instructions say to attach:
  • white to white
  • black to black
  • exposed wire to ground
but all i have are two old wires wrapped in what appears to be cloth. the cloth has become quite brittle.
So, how does one go about, safely, installing the new fixture?
external electrical box fixture installation pg3
Edit: More pictures as requested:
Is your box connected to armored cable? (Metal sheath wrapped around the two cloth wires) – The Evil Greebo Jun 1 '12 at 18:42
Can you post a pic of a more direct shot up into the box? – The Evil Greebo Jun 1 '12 at 18:50
OK, i added 2 photos. best i could get. – Meltemi Jun 1 '12 at 23:04
If the insulation is so far gone that you can't find the stripe, are you sure that moving the wires around isn't going to break it at or behind the box? You don't want to create any dangerous situations here. – Michael Kohne Jun 2 '12 at 18:59
FYI, the pipe-like threaded thing at the center of this electrical box is probably not a gas line, just an old-style mounting point for a fixture. – Shimon Rura Jun 3 '12 at 3:35
up vote 4 down vote accepted
The correct answer is: Redo the wiring all the way back to the panel.
The workable answer is: The wire with the black stripe on the insulation is BLACK. The other one is white. The junction box is probably not grounded, but I'd attach the ground wire of the light to the junction box anyways.
Safety wise, the ground isn't entirely necessary on a ceiling light as it is pretty unlikely that anyone will touch it.
But seriously, consider replacing the wire right back to the panel. It can be a pain to pull it, but modern wiring is much safer.
thanks! i don't think i'll find a "black stripe" on what's left of that brittle insulation. Any other (safe) ways to figure out which one is "black"? – Meltemi Jun 1 '12 at 17:42
@Meltemi The safest way is to call an Electrician. – Tester101 Jun 1 '12 at 18:05
@Tester101 - of course, but then I wouldn't be posting on a "DIY" website, would I? – Meltemi Jun 1 '12 at 18:13
@Meltemi I'm not trying to be mean here, I'm just trying to keep you safe. It's very dangerous to mess with electricity if you don't have proper training. – Tester101 Jun 1 '12 at 18:25
@Meltemi Some times the best answer to a DIY question is to call a professional. – aphoria Jun 2 '12 at 11:31
Use a NCVT (non-contact voltage tester) and see which of the two wires alarms when the switch is on. That will be your black/hot wire. If both of them alarm, stop, do not pass go, something else is wrong.Non-contact votage tester
For the ground, you don't have one. The safest thing to do is run a whole new wire back to the panel. Anything else is "less than safest".
I got a NCVT ($17), thanks! Good advice! – Meltemi Jun 2 '12 at 14:14
