We want to install a dishwasher in our kitchen, however the cabinet box is only 23" deep and dishwashers are usually 24 inches deep (as I understand). This would pose a problem when opening a bank of drawers that are perpendicular to the dishwasher. The cabinets were built on-site/in-place and cannot be removed. We were considering "chipping away" part of the wall studs behind where the dishwasher would go in order to gain an additional inch. However, this method is a bit awkward. Does anyone have a clever idea on how to solve this problem?
up vote 5 down vote accepted
You can definitely get dishwashers that are not as deep as the standard, though selection will be more limited.
One thing to consider is that the dishwasher needs a bit of clearance and wiggle room, so you'll likely need to accomodate more than 1" difference.
I would recommend against chipping away at the studs in you wall as this will reduce the strength of the studs and wall significantly. If this is an internal non-load bearing wall this might be OK but this would be a big problem if it were a load bearing wall.
I think the best/easiest solution is just to find a different dishwasher that will fit your space.
Thank You for the cautionary note. The studs are indeed on an outside wall, so we will not be adjusting them. – RET Jun 3 '12 at 19:45
I am having this exact problem (also in the vertical dimension) right now. I didn't get to choose my dishwasher. I did discover that some of the Bosch dishwashers are slightly less than 24" across and some less than 24" deep as well. There are the half size (16") ones as well but those tend to be really expensive for whatever reason (less demand and less competition I guess) and I don't remember if they tend to have less depth as well, or make up for their small width by being the full 24" deep.
My plan to get the dishwasher I already happen to have in is to cut out the back of the cabinet (just enough for the back parts of the dishwasher to go through, perhaps adding some horizontal and vertical strips around the hole to reinforce the cabinet) and maybe even the plaster wall, then cover the cracks between lath pieces with drywall tape and put on a coat or two of join compound, and paint. I will be careful NOT to damage either the framing or the lath. The dishwasher will still stick out about 1/2" so I will have to add trim to join it to the existing cabinet faces. (For the vertical dimension I need to cut and route a thin slice off the bottom of the countertop.) I don't have any drawers or cabinets at right angles though so it's ok if it sticks out a bit.
I have no idea if this is a good plan or if it will work but can post here the results (hopefully after this weekend.)
Reed
We were unaware of less-than-24" deep dishwashers, but will look into this. Thank You. – RET Jun 3 '12 at 19:45
By less than 24", I mean by 1/2 to 1 inch, not by much. At an appliance store they should have a big book or binder that includes all the specs and dimensions, I think you can also get these on the websites of Home Depot or Lowes, but the binders at the store might be easier to read and compare the exact dimensions of the dishwasher itself. – Reed Hedges Jun 6 '12 at 13:46
I did manage to get my dishwasher in by the way. I only needed to cut out the back of the cabinet, remove a strip of the top plywood layer of my kitchen floor for the bottom-front of the dishwasher to sit in (under the cabinets themselves was just original floor boards, what would be the proper subfloor in modern construction), and also took out a thin slot or strip of the front edge of the countertop. – Reed Hedges Jun 6 '12 at 13:48
THE one inch top of Ifb dish washer is removable ,you need to get it removed to fit under the cabin . ask your manufacturer .
Hello, and welcome to Stack Exchange. Your answer is a bit hard to understand (e.g. what's a "lfb dish washer"?). It would be great to edit it to make it clearer. – Daniel Griscom Mar 8 at 0:27
