We want to strip previously painted trim and baseboards. We have tried the Jasco paint stripper but it gums up and is not very successful, especially since the trim has a fairly detailed profile. Is there a more successful product to use?
Tell me more
I've had better luck with strppers if you cover it with plastic food wrap after applying it. Be aware that some strippers will disolve the plastic so test a sample first,if it disolves the plastic try it with wax paper. The idea is to keep the solvents from evaporating before the paint has softened. Any latex paint should peel off easily. If you have oil based under it scuff it with some sandpaper and reapply the stripper.The sanding seems to break the "shell" and allow the stripper to penetrate. As DAO1 mentioned be cautious of lead. Avoid using a heat gun and allow for plenty of vetilation. |
