are you planning on ripping the backing paper out? If not, then it doesn't really matter. If you were, it's likely not going to have asbestos as it sounds like it's just the paper from wall board. – DA01May 31 '12 at 4:42
I have uploaded an image i.imgur.com/s9JJU.jpg. Would you be able to take a look and give me your opinion? – skybreakerMay 31 '12 at 5:02
It looks like wall board paper to me. You can get it tested if you want but, again, if you don't plan on ripping it all out, I wouldn't worry about it. – DA01May 31 '12 at 5:09
I believe that asbestos is only found in drywall from the 50's to the 80's (and even then its not a given) - what year was your house built? – StevenMay 31 '12 at 13:26
