The gauge on my well pump is shot (reads 0, even when there is good pressure). I've purchased a replacement, so what are the steps I should follow to replace it?
This may be to do with your other question, why is the gauge broken in the first place? Once you give us some more info about the pump we may be able to help but you should fix the problem before replacing the pressure gauge – UNECS May 17 '12 at 2:53
@UNECS The gauge was broken when I bought the house a couple months ago. It just rose to the top of the list of fix. The pump running constantly is new. – C. Ross May 17 '12 at 10:08
  1. Turn off the power to the pump.
  2. Turn off the feed to the house (there should be a valve between the pressure tank and rest of house). This is simply to make the next step easier.
  3. Drain any water from the pipes where the pressure switch is screwed in. Usually there is a sed valve.
  4. Unscrew the existing gauge.
  5. Check the T where the gauge was screwed in for build-up/blockage. This may be what messed up the existing gauge in the first place. If there's any, clear it out as much as possible.
  6. Use teflon tape or pipe dope on the threads, and screw in the new gauge.
  7. Turn everything back on.
4A - get same type gauge (pressure range, fitting size) – Mark Schultheiss May 17 '12 at 16:56
